was thinking the p182 front audio connectors
what i dont like is the ide ribbon you get with the front plate - especially if I put it in a P182........ what do you do bigdave?
If you dont mind voiding the warrenty on the sound card you can carefuly cut the ribbon into 5 strips then celletape them into a cube. But i personally wouldn't do that. As for the front audio connectors i presume you can but not possitive.
i see mate.......... pity they cant release a round cable for it - i would deffo pay for one! especially a longish one which you can stick behind the case!
what do you do with regarding your audio connections?
