Actually, to be fair, the cd rail thing got me at first when I did the exact same thing as the OP!
The rail thing is quite handy once you've screwed them on the first time, and it makes for easier re-configs later on if like me you're always fiddling with your watercooling loop!
haha - i did read the manual - it just confused me a little - a picture is worth a thousand words Loving this case - has been a bit tricky to put together, but its worth it....... The wires at the back is good, but had to squash em in very hard when sticking the case panel back on
