p182 fans help quick!
7 Nov 2007
Hi I'm building a comp right now, I'm replacing the stock tricool fans with noctuas, but I forgot to note down which way they face! I figured the top and rear fans blow outwards, but I have no idea what the bottom one does, does it blow towards the rear or front?
The one near the PSU you mean? It blows towards the rear of the case same as the top/back one (sucking air through the front of the case over the hdd bay)
I would have thought up is the best so the hot air doesnt swirl around at the bottom, wouldnt have thought it matters too much tho.
Yup with many PSUs with 1 120mm fan only you'd want something to give the PSU abitta breeze to keep it going with fresh air, also if you have hdds on the bottom then you'd want a fan there anyway to draw warm air away from the hdds then cool it before it hits the PSU and then get exhausted by the PSU out the back.
There are already 2 fans at the top so airflow is well managed there.
