Got this case the other week and got round to finishing my build, a joy to work with but i can not for the life of me figure out how to install fans in the front.
i have two bog standard akasa fans at home that i had on my 900 that you push onto the 4 plastic pegs, there do not appear to be any such pegs on the front of the 183, none of the screws that came supplied with the case fit through the holes in the fan. Also the case has these 2 weird brackets that i assume you mount the fans onto, but again i cant work it out.
im sure it is something very easy but its driving me mad! has anyone installed fans in their 183 and could you provide any advice?
Many thanks
DiCe!/Alex
Many thanks
DiCe!/Alex
many thanks for the quick reply
