Hi Guys
I bought a Gentle Typhoon 800RPM to replace the top tri-cool exhaust fan. However, it won't fit in!
The existing tri-cool is mounted with two screws only on one side. The top edge of the other side simply rests on two tabs suspended from the ceiling of the case. The edge of the Gentle Typhoon is too thick to go inbetween the tabs and the ceiling and the corners get in the way.
Anyone else replaced the top fan? Custom mod?
Thanks.
Thanks.
