P35C DS3R 426 FSB wall!
8 Jun 2006
Hertfordshire
Hi Guys
I have a E6420 in the above board with 2gb Ballistix 5300 and I think I have a FSB wall stopping me clocking higher than 3.4ghz?
Even if I use a multiplier of 6 instead of 8 I can't got passed 426 which is only 2.5ghz :confused: it doesn't even show the bios screen just starts/restarts and sets some of the chip settings to auto :confused: My memory is set to 2.00 = 1:1 834mzh and I know the Ballistix can go higher so I can't see it being that, all other bits are disabled in the bios!
No matter what vcore I put through it, running a Thermalright 120 Extreme cooler with a large silent fan.
Is the FSB wall caused by the motherboard? If so is there any way to correct it?
Any advice would be helpful :(
It's possibly the CPU. Some of the E6400's had a 417mhz wall. Mine did.
Have you disabled all the unneeded options in the BIOS as listed in the DS3 guides?
Ah I thought it may be the case!
It does state on the box 1066mhz FSB though? Or am I missing summit here ?
Damn it :(
Damn it :(
Yeah, your missing something, 1066FSB is achieved at 266mhz. Intel chips have a quad pumped frontside bus.
So your 426Mhz FSB is 1704FSB in 'intel marketting speak'
