P35C DS3R CPU cooler?
1 Jul 2007
Various
Im looking at replacing my Intel stock CPU cooler on this mobo. However, the mobo heatsink seems awfully close to the CPU socket. Im not sure if it actually is closer than on other mobos-this is the only mobo I have ever worked with. However, is the spacing of it going to be a problem at all when choosing a heatsink, or are all motherboards like that?
Cheers-Im looking at one that doesnt involve backplates though-obviously the Freezer 7 is just push pins, but Ive heard great things about the Scythes. Does anyone know which of them will fit?
If the Tuniq Tower and the Thermalright Ultra 120 fit then any of the Scythes should. It's always worth doing a bit of research for yourself and visiting the cooler manufacturers' web sites as they usually have motherboard compatibility charts.
Ive looked on the Scythe website and couldnt find a chart-guess I will keep looking, and if I cant find one Ill go with the Arctic.
Fair enough, that will be bought along with a couple of nice Sharkoon case fans when the trusty student loan comes in! I assume the Freezer 7 will fit in a Thermaltake Soprano case?
I've just fitted an old XP-90 cooler to mine (with the 775 adapter) and it fits wonferfully.
Didn't think it would but there's loads of room. I bet there's not many coolers that this board is incompatible with.
