P35K Upgrades?
21 May 2013
I'm thinking about upgrading the WiFi and DVD to bluray, just not sure which wifi card to go for, or where to source the bluray.
Any recommendations?
Fish
You'll need to find if it takes a 12.5 or 9.5mm optical drive (I think that's the 2 sizes of slim drives) then just pick whichever one you fancy as the faceplates will pop off so you just swap it for the one on the current drive and it'll look stock.
Have you upgraded the wifi ? I've never had so many problems like now, with the signal dropping a fair bit. I had to use a cable to install updates as I just wasn't able to connect.
If you're still looking for a wifi card I'd consider the Intel 7260 AC, 802.11AC + BT4.0. I've been considering one myself for a new build.
