27 Aug 2009 at 11:28 #1 daven1986 daven1986 Soldato Joined 29 Oct 2005 Posts 3,298 Hi, Just wondering if these 2 processors use the same ram? Thanks Daven
27 Aug 2009 at 12:07 #2 mattyfez mattyfez Soldato Joined 12 Apr 2007 Posts 13,063 More than likely it will be DDR, but could be DDR2, you would have to check the mobo. It depends on the motherboard, not the CPU
27 Aug 2009 at 12:14 #3 daven1986 daven1986 Soldato OP Joined 29 Oct 2005 Posts 3,298 it is ddr I think. Guess I'll just shove another chip in and see if it fits / boots! Thanks
