c0caine said:
is there any boards that i could use for an AM2 chip that have onboard graphics?? or would i be better with a cheap gfx card that could be upgraded later?
Asus M2NPV-VM Micro ATX (Socket AM2) PCI-Express DDR2 Motherboard (MB-144-AS)
M2NPV-VM provides rich multimedia features for entertainment and advanced specifications for performance. Its unprecedented integrated video quality, Dual VGA out(DVI-D & RGB), HD audio, HDTV out interface(with TV out module) and 1394a support. The NVIDIA® GeForce™ 6150 GPU Northbridge supports Microsoft® DirectX 9.0 Shader Model 3.0, dual VGA out ( DVI-D and RGB), NVIDIA® PureVideo Technology with unprecedented integrated video quality, TV-out, and PCI Express interface. The NVIDIA® nForce™ 430 MCP Southbridge delivers NVIDIA® Gigabit LAN, and NVIDIA® MediaShield storage management technology allowing easy RAID configuration (RAID 0, RAID 1, RAID 0+1, RAID 5 and JBOD) for Serial ATA 3Gb/s. The motherboard features the NVIDIA GeForce 6150 chipset that supports superior HDTV-out functionality with a higher resolution to1080i and 720p formats, which are clearer than traditional formats allow. ASUS M2NPV-VM motherboard bundles a HDTV-out module that helps you enjoy the high-quality scaling and filtering technology.
- AMD Live!™ Ready
- NVIDIAR GeForce 6150 + nForce 430
- Dual-channel DDR2 800/667/533
- PCI Express architecture
- Integrated GeForce6 GPU
- Dual VGA Ouput: DVI-D & RGB
- HDTV out interface (HDTV/AV/S output module was bundled)
- 2 x 1394a Support
Full Specification
Price: £54.95 (£64.57 Including VAT at 17.5%)
I reackon your best off getting an onboard one. Was looking to do something similar for one of my friends
