I've got a laptop, its got a Pentium 4, 3.4Ghz processor.
I've been measuring the temperature recently and its idling at 60 degrees basically from a cold boot which surely is too hot to start with?
ANy sort of stress, eg running norton antivirus will take the temperature up to around 73+ degrees. Surely this cannot be healthy?
When gaming, the temps go up to around 75/76 degrees. Within the hour, negative CPU spikes occur, i.e the processor drops its speed, presumably to cool it down? This results in a performance drop in game making it unplayable for a short period of time. I know the P4's have their thermal control circuits which throttle the CPU at a certain temperature. However i've noticed with a program that this doesen't happen.
Instead, what i think is happening is the CPU is being slowed by the ACPI which controls when the laptop fans come on and cuts the processor speed when its running on batteries etc. ACPI also has a function to cut CPU speeds when it gets too hot, which I think is whats occuring, as when I run throttle watch, which monitors the P4's thermal control circuit (i think) and not the ACPI output, nothing happens in the throttling graph, even when these spikes occur.
I asked my vendor about this and they said these sort of temperatures are normal.
My question is this, if the computer in some shape or form is cutting the CPU speed, presumably because its too hot, surely that means either
a) the cpu is overheating
b) there's something wrong with the ACPI or whatever controls the CPU throttling
Anyone out there want to advise me as to whether this is normal and/or what the actual problem could be as i feel this could mean somethings seriously wrong and i need to take it up with the vendor, who doesen't believe anything is abnormal about this.
Should a £2500 laptop really be underperforming after a year? Is this accetable?
Cheers
Cheers
Looks like it is throttling at around 76oC.
