P45 DS3P BIOS UPDATE PROBLEM!!!
16 Aug 2004
Bury
Ok so I've had my DS3P for about 2 weeks now and been having a lot of trouble with stable memory timings and mhz.
The revision of my bios on the board was F6 so I went to the Gigabyte site and found bios update F7 which stated 'Support DDR2 speed to 1333MHz and beyond by overclocking'
So I thought I'd give it a try, put the new bios on a usb stick, booted to bios, and flashed the bios to F7 the way anybody does.
It stated everything went fine, new bios installed etc whatever, PC rebooted and nothing, everything powers up and stuff but the pc just doesnt post at all.
Tried clearing the cmos and still nothing, is this the end of this board as we know it or can anything be done?
Ta
CaNNoN
Remove the 24 and 8 pin power connectors from the mobo, then plug the 24 pin only and see if it fires up, then switch off and plug the 8 pin in also and hope that it fires up.
