yes very...seems only foxconn mobo that have it
It's not just foxconn motherboards, it's any motherboard using foxcon's socket. This includes some EVGA and MSI boards, and presumably others too (Could be Asus, gigabyte, DFI, etc etc). One board mentioned was the EVGA classified P55, which they think around 50% of the boards used this part.
Just checked my GD65, its a foxconn connector, well it says foxconn on the retention plate on the rear of the pcb.![]()
Hopefully my "lowly" 750 will mean it wont be quite so power hungry as the 800 series due to no hyperthreading, that and the fact i only use it for gaming so it isn't on for long periods.
You reckon the mobo manufacturers will man up and replace the boards with suspect sockets on?
so...it only happens when you overclock?
