P5B Deluxe WiFi AP Problem
15 Jun 2008
I have the above mobo with a Q6600, 4 x 1Gb of Corsair 6400 DDR2 and a Seasonic 600W PSU. HSF at the moment is an Arctic Cooling Freezer 7 Pro and it's all housed in an Antec P180 case.
I find that I can fairly easily clock my processor/board up to 7 x 400 for 2.8GHz, providing that I lock the PCI-E bus to 101 rather than 100. The CPU does need some extra voltage set in the BIOS for this, but given that it's VID is 1.25v and there is a degree of undervolting by the mobo anyway, this isn't a problem even for my low-end HSF to cope with.
Prime95 running on all 4 cores seems stable for as long as I care to run it. No problems with general usage, games etc either.
But...
About 1 time out of every 2, when I cold boot the PC I get 1 of 2 types of failure during the POST:
1. The 'overclocking failed' message, or
2. Something referring to 'Boot Block' (stupidly, I haven't noted down the full text of that message).
Each time, I just need to remove mains power to the board for 10 seconds or so and power up again, usually successfully, and once up the PC is stable and solid.
I know my motherboard is getting on a bit and perhaps isn't the best choice for a quad (it started life with a dual installed) - but before I have to think about whether I want to pay to change it and take my chances on that resolving my issue, is there anything I should look at to see if I can fix my current setup? It does seem strange that a Prime stable clock should cause boot errors, but then I'm no expert so any help appreciated...thanks.
mines similar - as soon as you get to higher fsbs then no matter the mobo voltage you can get issues like that
for instance if I run at 3.5 gig x 8 ... can run prime for9 hours, and it will reboot most of the time when I ask it to
but occasionally you turn it on and nothing !
:( I thought that might be the case.
On the off chance, did you (or anyone) find anything at all in terms of BIOS settings that affected this behaviour? Or particualr BIOS versions that were better or worse than others?
If not, I guess the time has come for a P5Q or similar.
