well i have had this board a while now and seem to be getting some good clocks from this board.here are some of my conclusions and findings so it may help others.
p5b-dlx user,if you can post your oc settings for your board,it may help others.
my board under volts vcore by 0.03v.if i set it to 1.5v,i get 1.47v.if i set it to 1.33v i get 1.3v.i dont know if anyone elses does this,it would be interesting to find out from more board users.
i used everest ultimate and cpu-z to check out the voltage drop.both report the same vcore so it seems correct to me.
if i boot to win with the fsb higher than 450,my pci-e switches to x1 mode.i have dicovered on mine that if i set the voltages like below it does not do it.
vcore=1.33v (500fsb i'm at now),obviously this one will be differant with each person.
vmem=2.3v (my mem dont seem to like over 2.3v)
fsb termination voltage=1.3v
nb vcore=1.25v
sb vcore=1.5v
ich chipset voltage=auto
the onboard sound is ****,i dont know if it is the driver or the hardware but it causes slow boots and crackling sound.use a seperate sound card.
there are problems with the jmicron controller if using a ide dvd/hard disc on it.disable it and use a sata dvd/rw and sata hard discs.
sometimes this board does double reboots,i have discovered this seems to be the board changing the strap setting.it dont seem to cause me any problems tho'.
at the moment its doing 3.5ghz(500fsb)at 1.33vcore(1.3v with drop) with mem at 1000mhz 1:1.tested pi 1m(16secs),and orthos for 1/2 an hour.seems fine.temps are 29-32c idle,52-53c running orthos.
i hope this helps others.
nb vcore=1.25v
sb vcore=1.5v
