For my first build iam after either off these the reviews ive read have been good for both boards, with the DS3P the better one for OC. Only thing ive noticed is the DS3P has a FSB1333 and the P5B 1066, iam guessing the higher figure one is better?
hai said:DS3P will support the new 1333FSB cpus, get that imo![]()
Big.Wayne said:I don't think their is anything better than the P5B-Series for Conroe, I doubt the DS3 is better? Both boards run 1066MHz System Bus but neither will have problems running 1333Mhz-System Bus
If the system bus thing is confusing think of it another way
200MHz-FSB= Allendale Chips
266MHz-FSB= Conroe Chips
333MHz-FSB= Future INTEL Chips
400MHz-FSB= The level most overclockers reach without too much fuss
450MHz-FSB= The better boards can hit this level, turns an e6400 into 3.6GHz and an e6600 into 4GHz (if you lucky and have the kit!).
500MHz-FSB+= Only a well made board has any chance of running this high and being stable
pastymuncher said:Only the DS3P rev 3.3 has native 1333 support.
markyp23 said:Does this mean that anything above the 425FSB will have increased performance as it has moved to the 1333 bootstrap?
Darg said:I believe he means that DS3P supports 1333 without a BIOS update. My impression was that the DS3P is pretty much just a DS3 v.3.3 with an updated BIOS anyway.
Darg said:What is the difference between the DS3 3.3 and the DS3P? Or are they the same board?
If the only difference is that one PCI slot changed for the 4X PCI-E slot then I'd go for the DS3 3.3
