P5E3 Deluxe WiFi-AP@n ?
8 Nov 2007
Firstly Hi All great forum!
Secondly Im about to get a Asus P5E3 Deluxe WiFi-AP@n and just wanted someone to confirm that this board comes with the ai remote control.
I mailed Overclockers about the P5E3 Deluxe they are selling asking the same question and got a reply saying "Sorry we cant confirm if it does" which I though was a bit crazy?
Im pretty sure that the P5E3 Deluxe WiFi-AP@n comes with the remote and the P5E3 Deluxe doesn't but could be wrong?
If someone could confirm this for me if they have this board it would be much appreciated
Many Thanks in advance!
I think the main reason OcUK were not able to tell you with regards the AI remote control is because the only way to be sure would be to open a box up and I'm guessing it can then no longer be sold as a brand new item.
I went to the ASUS website and looked at the specification and box contents for both the P5E3 Deluxe and P5E3 Deluxe WiFi-AP@n and the remote doesn't appear listed on either.
It's only reviews on the P5E3 Deluxe WiFi-AP@n that seem to mention it so I would assume that it is only that model that comes with the remote.
I still can't decide on which of those boards to go for.
You've got the P5E3 Deluxe available at £173inc or
P5E3 Deluxe WiFi-AP@n available at £197inc
I'm just trying to decide if the onboard pre-n wireless is worth the extra £25 or not as effectively that is the major difference between the two boards and I really can't see myself using the wireless on a "desktop" machine.
Thanks for the reply stoofa my findings are the same as yours really. I checked the Asus website and couldnt find it listed either. I posted the same question on the Asus forums and had a reply saying that the P5E3 Deluxe WiFi-AP@n does come with the remote. So I think Im going to go for that one.
Thanks again!!
