any advice on the below would be greatly appreciated
i have the same set up as below, apart from 4gb of corsair ddr3 1333 (
MY-134-CS)
had this running for months @ 3.0ghz, updated the bios to the latest version, now struggling
ASUS P5E3 Quad-Core Setup Guide for 450FSB
CPU Features
Ai Overclock Tuner Manual
CPU Ratio Control Manual
CPU Ratio Setting 8
FSB Strap to North Bridge 266
FSB Frequency 450
PCIE Frequency 115
DRAM Frequency DDR-1800
DRAM Command Rate 1T
DRAM Timing Control Manual
DRAM Timings
CAS# Latency 7 DRAM Clocks
RAS# to CAS# Delay 7 DRAM Clocks
RAS# PRE Time 7 DRAM Clocks
RAS# ACT Time 15 DRAM Clocks
RAS# to RAS# Delay Auto
REF Cycle Time Auto
WRITE Recovery Time Auto
READ to PRE Time Auto
READ to WRITE Delay(S/D) Auto
WRITE to READ Delay(S) Auto
READ to READ Delay(S) Auto
READ to READ Delay(D) Auto
WRITE to WRITE Delay(S) Auto
WRITE to WRITE Delay(D) Auto
DRAM Static Read Control Disabled
DRAM Dynamic Write Control Disabled
Ai Clock Twister Strong
Ai Clock Skew for Channel A Auto
Ai Clock Skew for Channel B Auto
Ai Transaction Booster Enabled
Boost Level 2
Voltage Settings
CPU Voltage 1.475
CPU PLL Voltage 1.6
FSB Termination Voltage 1.5
DRAM Voltage 1.96
NB Voltage 1.61
SB Voltage Auto
Clock Over-Charging Voltage Auto
Load-Line Calibration Disabled
CPU GTL Voltage Reference Auto
NB GTL Voltage Reference Auto
CPU Spread Spectrum Disabled
PCIE Spread Spectrum Disabled
MY-134-CS)
CPU Features
CPU Ratio Setting 8
FSB Frequency 450
PCIE Frequency 115
DRAM Timings
REF Cycle Time Auto
Boost Level 2
Voltage Settings
CPU Voltage 1.475
CPU PLL Voltage 1.6
DRAM Voltage 1.96
NB Voltage 1.61
SB Voltage Auto
