P5k deluxe wifi problem . . .
29 Mar 2007
Please can someone help me as im close to breaking point.
Iv recently bought 2gig of OCZ Reaper ram and a P5k Deluxe wifi motherboard.
It runs okish with no bios twiddling, but when i try tinker with the settings and reboot it will crash just before the windows login screen appears.
Iv been trying to follow this overclocking guide http://forums.*****.net/showthread.php?t=110267 but it will never fully boot to windows after changing the settings :(
Just before it crashes the computer makes a little kind of squeeling noise - not sure which component it is but it could be either the psu,thermal heat sink or the HD.
Basically its running on deafult settings and i really want to get it running at 1066fsb as it is capable of doing so.
Even when i try adjust the ram settings it crashes.
My cpu is a Hiper 580Watts
Iv only got a budget GFX card at the mo so it wont be that and the BIOS version im using is 0404.
Ideas anybody ????
Ermm, not easily perhaps.....try listening with the side off, but doubt it will really help :(
