I've set my FSB to 400MHz, I'm using a Q6600 CPU with a multiplier of 8 and 4GB of PC2-8500C5D memory.
I was wondering whether I should increase the FSB Strap to 400MHz and get a 1:1 ratio between the FSB and memory, letting me lower the voltage on the memory, or leave the Strap at 266MHz forcing me to increase the voltage to the memory and most likely the Northbridge.
I've heard it a few times that Intel CPU's benefit (suggesting AMD's don't???) from a 1:1 ratio but hopefully someone here also has some knowledge on the matter.
To elaborate further, when the FSB Strap is 266MHz I have the memory on 500MHz, and the vdimm is 2.1. If the Strap is set to 400MHz I put the memory to 400MHz letting me have the vdimm on 1.8...
I guess what I'm trying to figure out is, is there a major difference in performance when:
Lower FSB Strap = 1:1 FSB memory ratio and lower voltages
Higher FSB Strap = ?:? FSB memory ratio and higher voltages
Apologies if this has been answered a million times before.
