Im a bit concerned about the amount of heat im getting from my heatsink on the mobo.
My cpu is overclocked to 3Ghz
E6600
But even prior to that i get massive ammounts of heat from the motherboard.
My CPU runs fine at around 37-40oc solid but if I feel around or touch the mobo HS its VERY scorching hot, according to my temps on my mobo software it says its at 35oc but it feels about 200oc lol
Is this common for this board? or should i be very worried?
voltages are as follows, if this helps...
+5.0 = 4.86V
12v = 12.10V
Also for the E6600 what is a suitable heat? My previous AMD's iv had used to run VERY hot, like 50+ on load but this is my first Intel ...
E6600
+5.0 = 4.86V
12v = 12.10V
