P5N-MX Overheating, new case??
29 Sep 2010
Hi all
Within the last couple of days we have had some really HOT weather and my bedroom, where my computer is located has been very warm to say the least.
My Asusp5-mx board seems to be overheating when running more than "two" main applications, i.e mozilla firefox and VLC media player, if these two items are open at the same time, it will simply freeze after a short period of time...
it has the LGA775 socket with the intel Core duo 2.0ghz processor, 3gb ram, a thermaltake CPU fanless copper base and piped heatsink. 1x 120mm fan at the rear "exhaust" sat less than 1 inch away from the heatsink. another 14cm fan inside the PSU (again only an inch away from the heatsink. and an 80mm fan at the front panel. ( I did have another 80mm fan on the side, but the bearings have collapsed.
Prior to this hot weather it has been fine for well over a year "on 24/7!" with a stable temp average of 32*c to 34*c (depending on load, 100% load= 34*c) highest temp.
I investigated the problem last night and found the bios battery AND (the realtek on board sound chipset) (the silver block, next to the bios battery?) either way the whole chipset surround the bios battery and ram sticks was hot to say the least. when I removed the bios battery to reset the bios I took the battery out and burn't myself, the battery was that hot!
I'm not certain whether it is down to the cooling, as when it crashes it's showing an indicated "42*c" at the time of the crashing "cpu temp" motherboard would be approx 52-54*c
I have been thinking of buying a new a case where further fans can be fitted i.e 5 fans in total to increase further air-flow. as I don't think my X-blade case even with all the fans fitted and working, would cut it.
any idea's?
Its the first time I've come across an overheating chipset.. it's been running fine for at least a year on "pretty much" 24/7! and never had any problems since the build.
could my board be on its way out? or do I just need to update the cooling with better airflow case and further fans?
In recent times, I've noticed when I have rebooted after a power cut (house power-cut) or reboot after a windows update the sound icon in the taskbar isn't their. after a few reboot's it then appears... (although thats probably down to the OS..)
here's a list of my sensory info
--------[ AIDA64 Extreme Edition ]-------------------------------------------------------------------------------------- Version AIDA64 v2.20.1800 Benchmark Module 2.7.398-x64 Homepage http://www.aida64.com/ Report Type Report Wizard Computer ROB-PC Generator rob Operating System Microsoft Windows 7 Ultimate 6.1.7601 (Win7 RTM) Date 2012-07-25 Time 12:01 --------[ Sensor ]------------------------------------------------------------------------------------------------------ Sensor Properties: Sensor Type Winbond W83627DHG (ISA 290h) GPU Sensor Type Diode (NV-Diode) Chassis Intrusion Detected No Temperatures:
Motherboard 36 °C (97 °F)
CPU 44 °C (111 °F)
CPU #1 / Core #1 42 °C (108 °F)
CPU #1 / Core #2 43 °C (109 °F)
MCP 82 °C (180 °F)
Aux 23 °C (73 °F)
GPU Diode 59 °C (138 °F)
Hitachi HDP725025GLA380 34 °C (93 °F)
WDC WD20EARS-00MVWB0 32 °C (90 °F)
Cooling Fans: CPU 1205 RPM - note! there is no CPU fan as this is a fanless heatsink!
GPU 50% Voltage Values:
CPU Core 1.272 V Aux 3.712 V +3.3 V 3.312 V +5 V 5.564 V +12 V 10.275 V +5 V Standby 5.018 V VBAT Battery 3.088 V Debug Info F 46 FF FF / FF FF Debug Info T 36 44 23 / 255 Debug Info V 9F E8 CF CF A9 C6 A8 (01) Debug Info I C1 A023
I've been looking into buying a new case, I'm sure the problems come from air-flow, even If I fitted another 80mm fan on the side panel, i doubt it will be enough...
I have a budget of approx £50 to spend on a new case.
Here's some I've been looking at
NO COMPETITORS
the only problem with the above is reviews say they are filmsy and the turbine isn't powered, only moves from the air-flow from the 120mm fan located behind the turbine... (surely that would be more of an "air" restriction? anyone have any reviews from here?
another one I've seen is this -
NO COMPETITORS
anyone have any reviews on this from here?
if anyone can recommend a good case that can take 4 fans or more and has great cooling properties for around the £50 area, please post!
Thanks
First off remove the competitor links or you will be getting a free holiday.
Second, why are you looking at overpriced **** cases when you can get a better one for less from OCUK?
it's cleaned every 2-3 months depending on when it needs it.
dust isn't the cause for the heat, I know side panel fan has given up due to bearing failure, but even if I sorted that out, there would only be 3 fans on the chassis, 1x 120mm at rear, 1 80mm fan up front and 1x 80mm on the side, the other fan is a 14cm inside the psu.
really... I need a new case that has better air-flow design with the support for 4 or more fans to increase air flow speed.
I've had a look on OC's cases but are out of my price range.
can anyone recommend a good case for air-cooling?
Thanks
rob
ive only spent about a min looking and there is a stupid amount of cases for under £50 and plenty of them have extra fans and space for more
