P5N32-E cooler compatibility
Permabanned
28 Nov 2006
I'm looking to replace my freezer pro 7 as it makes a loud vibrating noise for a while after i've switched my pc on. I'm thinking of going for the noctua or the thermalright ultra 120 but i'm a bit worried that my heatpipes around the CPU socket will get in the way. Anyone else have this board with one of these coolers?
The Thermalright is fine - the heatpipes lift the main mass of the cooler well clear of the board. I've just taken a look - I have both, just not together.
M
The Thermalright is VERY tall. I've found it usually fits (just), but if the case has a fan in the side door then that won't fit. Certainly true of the Antec Nine Hundred and the Coolermaster Praetorian 762.
M
