P5n32-E SLI Bios Help
18 Feb 2006
Halifax
Hi guys
I am after some help with the Bios settings on Asus P5N32-E SLI MB they are as follows. Now I have entered the current settings are these correct ?? or if they need to be changed please let me know which ones, the spec of my PC is at the bottem of this post. The only settings I have changed in the bios upto now have been to disable the floppy drive and enter the correct timmings for the Geil Memory.
Extreme Tweaker
Nvidia GPU Ex [Disabled]
OverClocking
CPU Internal Thermal Control [Disabled]
Limit CPUID MaxVal [Disabled]
Enhanced C1 (C1E) [Disabled]
Execute Disabled Bit [Enabled]
Virualazation Technology [Eanabled]
Enhanced Intel Speedstep [Disabled]
LDT Frequency [5x]
PC Spec
Asus P5N32-E SLI
Core 2 Duo E6660
BFG 8800 GTX OC
GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra
Many thanks in taking the time to reply :D
What information are you looking for? Those boards are not good overclockers. You'll probably be able to get the CPU FSB upto about 333/1300 and after that it's probably all go a bit flakey.
If you have manually set the RAM timings then best run in unlinked mode as the RAM usually won't overclock much at the stock timings.
Ok what I would like to know are the settings from my first post correct in the bios ???
For instance should the below uptions be enabled or disabled, If I enable it will I get better performance with the Geforce 8800 GTX ???
Extreme Tweaker
