p5n32-e sli plus RAID HELP
J86
J86
23 Aug 2005
hi,
id like to install my 2x36gb raptor hard drives in raid 0 on vista 64bit
i downloaded the vista 64bit drivers from the asus site, but all it contains is like a setup.exe file and a few other things, nothing to put onto a floppy disk to install on the first stages of the vista install process
any help would be apprechiated
thanks
Hi
You dont need any drivers, set hdd's to raid enabled in bios, exit bios, hit F10 to enter raid setup, select the 2 drives for the raid and exit, then install vista.Vista will see the raid, and ask you where u want to install it (i.e. C:/)
