P5N32-E Sli wont warm reboot after exiting bios
22 Feb 2007
Hi,
After making changes in the bios, then f10 to save and exit it appears to resart but the screen just stays blank.
Im not doing a massive increase or anything for it to fail.
It just doesnt like doing a warm reboot it seems after being in the bios.
After it hangs I just switch it completely off for a minute or so then power on.
:confused:
Im using:
P5N32-E Sli
E6600 cpu
Corsair 2GB DDR2 XMS2-5400C4 TwinX (2x1GB)
ZM600-HP Heatpipe Cooled 600W Modular PSU
Zalman CNPS9700-LED Aero Flower CPU Cooler
2x Raptor Drives
Thanks
If you've not already done so, turn off the JMicron eSATA controller in the BIOS and/or upgrade to BIOS 0401. That usually sorts it.
I only came across your issues when useing the 0602 BIOS. My system had difficulty bringing up the POST. This seemed to be fixed when I moved onto the 0702 BIOS (now useing 0902 without any issues whatsoever). I'd make sure your chipset voltages are manually set, as that also helped with my issues.
