P5ND2-SLI dual core??
22 Nov 2004
Kent
I have a P5ND2-SLI and wanted to stick a dual core 2.66 that is on this weeks offer of the week, problem is i no that there was a problem with this board and the 2.8 dual core, i have looked at the website and it isnt much help.
does any one no if it will work :confused:
thanks
gavindo :)
I have the same motherboard . an in my book is say's it will not support the 820 only in singlecore mode., i would not risk anything above this model number..
the 830, and 840s are fine.
its just the 820s that suffer
i think a lot of nforce boards ahve this problem.
**i THINK** its somethign to dow with the multiplier being lower , and the board only recognises one core. im sure i read that somwhere
use the ASUS CPU support site. the P5ND2 - SLI wont support any of then newer 9XX series chips though !
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
search using motherboard
socket 775
p5nd2-sli
list off all the CPUs it supports :)
No. but the Asus P5N32-SLI supports both Dual Core and EMT64. It may be more expensive but it has the Intel chipset and Nforce 4 SLI for the Southbridge. I shuld have received mine on Saturday but City-Link *****d up the delivery and OC never advised me until I asked them. Still hopefully I shold have it up and running tommorrow night. At present I am using the P5ND2 SLI and you need extra power to support Dual core CPU's which this doesn't have.
