P5Q PRO OS Instalation Problem
3 Apr 2009
Preston UK
Q PRO OS Installation Problem
I am trying to load windows XP it gets as far as setup is starting windows then gives up. The BIOS settings are default not sure if the Sata cable should be in white orange or red socket.
Thanks in advance for any help.
I would use the red sata's as the the other two are for setup similar to RAID. Although I am running a RAID 0 array on the red sockets.
I’m very sorry to have wasted your time turns out it’s a bad installation disc.
I didn’t spot this as it was happening at the point where it should restart I just started to panic & thought the worst.
Again SORRY !!!!
