P5W-DH CPU voltage - where ?
12 Jul 2005
Just over your shoulder
Stupid question, I expct, but how/where can I adjust the CPU voltage on said 'board.....the option I looked at seems to just have 'Auto' as the only setting...... :confused:
You have to turn off the AI thingy under cpu configuration. Set it to manual.
Cheers for that.....will have a fiddle, mind you I have read that it is more about MCH volts on these boards, due to CPU not likely needing extra volts for the most part......going to have a fiddle with clocking as all I have done so far is try a simple raise of FSB from 266 to 333 (which seems to have worked a treat with no further changes :D )
