Others have done this before: Removed pretty tinsel eyecandy from NorthBridge of the P5W DH and slapped a 40mm fan on it.
Well I did this today. I removed all the factory installed heatsinks and TIM from NB. cleaned up, removed the tinfoil golden prettyness and added a cheapo 40mm Akasa and fresh TIM.
Result 15°C reduction in NB temps from 50°C to 35°C at idle. Not only that CPU temps have dropped by 2°C as well. I guess that the NB was acting as a little radiator, hot air rises as we know, or should. The NB is below the processor when the board is mounted in a tower case. So I guess with the NB at 50°C the CPU cooler had to deal with heat rising from the NB as well as cooling CPU. It's the only explanation I can think of for the reduction in CPU temp. Anyhow, imho replacing the TIM on the chipset and adding a fan to the NB is a good thing to do with this mobo.
I will see if I can get a stable 3.33Ghz tomorrow.
What a cruel twist it is to allow the selection of a 550Mhz fsb, yet limiting the Voltage to the MCH to 1.65v
I first read of the new revision boards about 2 weeks ago. I guess retailers will use up any old stock first.
