P5W DH + Geil 2GB ultra
16 Sep 2006
Cornwall then Norfolk now
I've just got my my system up and running and it's uber fast!
I think i've set the timings up right in the bios. I've set the first 3 options in the bios to 4 and the last option to 12 and then there is another option with 4. Then i've gone in to the DRAM freq and set that to 2.10 as stated on my ram. I've also set the option to say that i've got DDR2 800 in the over clock part of the bios.
Can someone just confirm i've done this right please?
Cheers
Carl
some more info
cpu-z reads my ram as the following under SPD tab PC2-5300 (333mhz) Part number CL5-5-5DDR2 same for other stick of ram.
Under the memory tab it reads
Freq - 400.7
FSBDram 2:3
CAS#Latency - 4.0clocks
RAS# to CAS # Delay - 4 clocks
RAS# Precharge - 4 clocks
Cycle Time (tras) - 12 clocks
Bank Cycle - 20 Clocks
My ram is GeIL 2GB (2x1GB) PC6400 800MHz CAS 4-4-4-12
ANy help would be great.
Whats the memory voltage at? think it needs to be 2.1 I would check that out I'm sure someone will confirm it, I'm only going by what I've heard before - check old posts on the same subject, do a search on Geil under titles.
