18 Sep 2006 at 10:08 #1 mtbaker mtbaker Associate Joined 4 Sep 2006 Posts 56 Hi Dumb question, but where are the memory ratio settings in the bios? I'm running on 1305. I think im going blind, cant see it any where
18 Sep 2006 at 10:15 #2 kevpuk kevpuk Soldato Joined 12 Jul 2005 Posts 3,005 Location Just over your shoulder Under ADVANCED menu > JumperFree Configuration (from memory.....can't be sure without a reboot )
18 Sep 2006 at 18:57 #3 mtbaker mtbaker Associate OP Joined 4 Sep 2006 Posts 56 Hi I'm not seeing it in their! Maybe i got myopia
18 Sep 2006 at 20:04 #4 Durzel Durzel Soldato Joined 10 Oct 2003 Posts 5,518 Location Wiltshire There's no ratios to speak of. Well, there is but it doesn't tell you what they are, which is quite annoying. If your FSB is 266, then 1:1 = DDR2-533Mhz The others are various combinations of 4:5, 5:4, 1:2, etc.
