p5w wireless trouble
13 Jan 2006
Wigan
ive just formated my machine installed all the drivers etc, come to connect to my wireless router which is passworded and it wont connect
windows says it cant connect, so i click diagnose, it says theres nothing wrong try again or try a new network.
so i try my laptop and it works fine.
i set the router to no password, and my pc connects no problems. so i put the password back on then the above happens.
im typing the password in right btw.
so i try all different drivers and still no avail. so i check in device manager and it says realtek RTL8187 wireless blah blah USB2.0 network addapter, is this right? the arial screws in to the back of the mobo, nothing goes in any usb
im connected atm with a cable accross my bedroom which has no problems.
can any1 help?
