P67-GD65 boot drive keeps changing.
8 Apr 2011
I have a GD65 and it keeps changing the boot order. From within the bios it changes the drive from my 1TB Caviar black to my 320GB Hitachi. There's no operating system on the Hitachi so it keeps coming up with "bootmgr.exe was not found". Even if I disable the Hitachi from being the secondary boot drive and take it off the list completely it still switches it around.
All my other settings such as my overclock don't revert to default so I'm not sure what's going on. Any advice?
EDIT: Not sure if this should be in the motherboards or hard drive section so I put it here.
In the BIOS you have an option to set what is the hard drive boot order. Look in the manual and you will see how to do so. That will sort your HDD boot issue out.
I've already done that.
There's a section which asks me the primary and secondary boot drive, even if I remove the secondary and keep my WD as the primary, it switches back even when I change the settings.
