- 14 Jan 2011
Bit of a long story so bare with me.
All of a sudden my PC has started to not recognise the location of my hard drive and I would have to reset and get into BIOS settings to assign the boot order again. Then I realised my DVD burner has stopped working, so bought a new one.
Then I couldn't get my MB to recognise this at all. After a lot of digging around I found that MSI released a utility to check the SATA ports on the p67a-gd65, all this utility does is check to see if you are using any of the Black colored SATA ports, if you are it advises you not to use them!!!
More digging and I found out that there is an issue with this board, more specifically with the Intel chipset which makes the Black SATA ports unusable.
Thats 4 ports gone! I am using all the white SATA ports for hard drives and one of the reasons I bought it was because I wanted the quantity of SATA ports.
See under B3 Stepping Ready
http://uk.msi.com/product/mb/P67A-GD65--B3-.html
Are you aware of this issue and is there a process to replace these faulty boards or know fix?
