P6X58D-E updated?
18 Aug 2010
I bought an overclocked system a while ago with the Asus P6X58D-E motherboard using bios version 0303 but a newer bios is out so I wondered if Overclockers ever brings out an overclocked profile which works with the new bios installed for customers like myself?
Have you flashed the new BIOS yet? If not, you might as well just stay with what you have unless the BIOS brings anything that you really need.
I have this mobo and just flashed it to the latest bios as it states to improve memory and system stability.
Flashing your bios will erase the oc settings, so they would have to be done again.
I doubt it, as each chip and board will need to be setup slightly different, what may work one board may not work on yours.
