It's been a while since I built my PC, can anyone recommend some decent RAM I can use in my Asus P8 P67 Pro, at least 8GB.
I don't mind if the performance is capped by the motherboard limitations, it would be good to use the same RAM after I upgrade the whole PC in the future - as long as it's compatible and using my current board as best it can.
Thanks guys!
Thanks guys!
