Okay I need some help here!
I just got my P8P67 Deluxe and I've had absolutely no luck in getting all my drives working together with the motherboard. I have 6 Drives in total that I want to plug into my system.
First issue I've had is getting the board to go beyond POST when I have any drives plugged into the Marvell SATA ports. If anything is plugged in the computer gets to the screen where you can press ctrl+m to configure a raid setup before rebooting.
Second issue I've had is being able to boot into Windows 7. At the moment I am only able to have my Corsair F90 SSD and Pioneer DVDRW plugged in. If I try and plug in my Samsung F3 1TB and my Hitachi 1TB drive into any of the remaining Intel ports the system just hangs at the Windows 7 splash screen indefinitely.
The odd thing is, once the system has actually booted up, with hot swapping enabled I'm able to plug these drives into any free SATA port (Intel and Marvell) and they work fine. The system appears to be stable, heck I can even overclock and it runs fine.
So far I've tried reinstalling windows and flashing the BIOS to the latest available firmware... still not luck.
Am I doing something wrong? I just want to get the board working with my drives permanently plugged in
The rest of my system specs if it's of any relevance:
Windows 7 64-bit pro
i5-2500k
Crucial Ballistix Tracer 2x2GB 1600 MHz
XFX Radeon HD5850
i5-2500k
XFX Radeon HD5850
