I'm in the process of building my upgraded rig and I reached the first boot stage tonight. I'm using a P8P67 Pro (from the MM), an i7 2700k and a Corsair H100.
Now I've built a few PCs in my time going right back to 486's but this bios is pretty detailed compared to any previous ones! To say I haven't a clue where to start is an understatement. I decided that the best policy was to load defaults (3.5ghz) and see what temps I am getting at idle; I dont have an HD connected up yet so it's purely bios based.
First issue is temps. Using two Apache's on the h100 I am getting 43c and climbing under idle in the bios on the medium fan setting. This seems high
Do I need to apply some AS5 instead of the stock stuff and re-seat?
Second issue was when I change stuff like the multiplier, it doesn't seem to have changed after rebooting; the reported speed is still stock even though the field for the multiplier is set to 40.
Finally, are there any guidelines to how to approach overclocking this board once I have it assembled? There seem to be plenty of tools and options, but it's knowing what order to change stuff in. What overclock and temps should I be aiming for?
