P8P67 LE (2 Problems)
25 Mar 2011
UK
Hi
Ok so my last p8p67 had same problems as new one i got from OverClockers, but the last one stopped working after 2 hours.
What problems i have ...
I have problem with a sound, when i connect for example headphones, i can hear some noises, they are gettin bigger when i for example connect external HDD, even when i scroll bar in FireFox... I did try to reinstall sound drivers etc, but no success...
Next problem is dual boot, when i run PC, it restarts and boot again, my Bios version is 1003.
Any ideas?
Cheers
The double start - reboot thing would normally only happen when you have made a change to your BIOS or when you have completely powered down. And is normal.
The sound issue I have no idea about.
hmm - no I mean if you had changed a setting in the bios.
That double boot also happens if you power off at the wall.
1Day, it should not happen even on power off. I have a situation where about 2 in 5 times it will dual boot, the other 3 times it runs fine with my P8P67Pro
maivo252 does this happen every time or just sometimes?
Regards
Fred
Regards
Fred
Everytime ;/ , just not when i reset my PC.
If your not using the marvel connecter i think you can turn this off as it tries to use it first and then restarts when it doesnt find anything attached?
Thats what mine did anyway.
Thx i already figured it out, but what about sound, i think im gonna send this ****ty mobo to OC again and get Gigabyte or MSI.
Cheers
