P8P67 Pro and Auto Tune OC Question
7 Feb 2011
Holywood, County Down
Hey all
I just installed my new build Asus P8P67 Pro and a i5 2500k. From Asus Suite II I used the Auto Tune and picked FAST.
Interestingly it seems to have changed the BUS Freq as well as the Multi. I thought for OCing these i5s that only the multi was upped.
After the several reboots it reported back with an OC of 4.326Mhz as follows
Multi x42
Bus Freq 103
VCore 1.296
Under Prime Temps are just hitting 60.
Under Auto Tuning is that Bus Speed or should I set it back to 100 Mhz manually.
Ta in Advance
You are not supposed to mess with the bus freq. although some insane benchers like to knock it up a tad to get the most extreme clock.
Seems odd auto tune changed it.
Auto tune does that for some reason, put mine up to 103 as well, just manually drop it back to 100 and raise the multiplier.
