P8P67 Pro B3 - Device Manager
11 Mar 2011
Hi,
ASUS P8P67 Pro
Windows 7 64bit two devices showing as UNKNOWN DEVICE.
I have installed every driver under the sun and still it shows two devices.
Please can you help.
Steve.
have you installed the chipset drivers from the asus website, they arent in the driver section, but their own seperate section, you may have overlooked it, and downloaded all the drivers but not the chipset.
I had to install something like "Machine Interface Drivers" off the driver disk that came with the mobo to get rid of my last unknown device.
Yes latest.
SOLVED IT
You must install from CD. However when you try the setup program it will - already installed or newer version present.
I just went into device manager, and browsed, select x64 folder from the cd usb3 and it found both of then.
Happy days.
IMAGE TIME me thinks.
