P8P67 Pro Question
3 Apr 2011
P8P67 Pro Question double boot
Hi all
Im new to this forum but I was just wondering should my system do this, It posts 3 times, ie it starts stops and on the 3rd time will actualy boot into windows, is this meant to happen? and is there something in the bios to stop this? My specs are here with a 1tb sata 64mg cache hhd.
http://www.overclockers.co.uk/showproduct.php?prodid=BU-063-OE
I,d be grateful for any help
after abit of digging around, i found i need to upate the bios to stop this
http://support.asus.com/faq/detail.aspx?SLanguage=en&p=1&m=P8P67 PRO&s=39&hashedid=HMMvTCuBcZLfu2YL&os=&no=8A27BE1D-ADB8-B93A-11DE-799C48A6BC09
thnx, hope this helps for anyone else that has this prob!
FAQs
Recently, I bought this motherboard to build my new system. The system always does POST twice every time when I cold boot or boot after AC power loss. Is this normal?
Solution
The new version BIOS has removed the extra full rest at POST. Please update your BIOS to version 1204 or later to resolve this issue. Please select your motherboard model, and download the appropriate BIOS file from this link: http://support.asus.com/download/download.aspx?SLanguage=en-us.
New bios = 1502
