- 16 Nov 2012
Hello all, wondered if anyone can help me here.
I've had my computer running stable for a couple of weeks now at 4.4ghz, with manual voltages set on RAM (1.5v, non XMP Kingston 1600mhz). When I boot into the BIOS however, next to where the manual voltage option is, it shows another number which I take to be what it's actually running at.
Here's a screenshot I found:
Next to my DRAM voltage which is set to 1.5 it's showing around 1.61. Is this normal, or related to LLC etc? Memory is not overclocked in the slightest, only CPU/GPU. I know lower voltages are better so how would I go about correcting this?
Same thing happens on the PCH voltage. I set it to 1.1 and it shows 1.2ish after reboot.
I've been having problems with my USB ports (randomly disconnecting and reconnecting), could this be related? The VCCSA is manual too but that's behaving itself and shows the same as I've set it (1.05)
