P9X79 PRO problem HELP
11 Oct 2011
London
Hello guys,
So I just got the above motherboard with 3820, and had OCUK update the BIOS for me.
Plugged everything in and no boot, just the reset switch comes on and the little light above the TPU switch. and a continuous beep beep beep beep...noise.
please help!
P9X79 PRO
3820
16GB Kingston quad channel ram
850 psu
670 msi graphics
if you need any more info please let me know!!
Thank you,
What PSU is it? Make and model please.
Also is the RAM and CPU cooler seated properly?
Make sure the 4/8 pin CPU connector is connected and same goes for 24 pin ATX cable.
the reset light and the light next to it is on - on the mobo but nothing else spinning or coming on
Thank you all very much for your help. ~PC now would not even boot up at all, even after checking all you suggested. Sadly had to send it back.
