pa120.2 in pc-7 roof?
23 Jun 2004
Blackburn
Anyone know if a thermaltake pa120.2 rad will fit in the roof of a lian li pc-7. Thinking of putting a second loops in rig and will be installing the rad in the roof. pa120.2 rad looks like it would fit but im unsure if the cables coming from the psu would clash.
Can anyone confirm if it will fiit or not?
How is watercooling in a pc7?.
I have the pc60 which is the same case. I am looking at the danger den series for my first venture into watercooling but i am of the mind that a bigger case is needed.
i would like everything in house as apposed to half in half out. Is it at all possible to have all the equipment in this case?.
Chris
well in mine im currently cooling cpu and gpu, all inisde but the rad mounted to the back of the case. I fancy a second loop for gpu so would have to put rad in either the roof or at the from 120mm intake, but that woud mean losing the hdd cage there. You can get everything in there, and run 2 loops with 2 120.1 rads if you dont mind a bit of modding :) a good example of this is here http://forums.overclockers.co.uk/showthread.php?t=17663542&page=1&highlight=project+black I doubt matt100 will mind the attention :p
I've got a PC7 here with a 120.1 in the front and a 120.1 in the back. You do need a hefty pump to overcome the back-pressure and the front drive cage needs to be rotated 90 degrees, but it works well enough.
