- 18 Oct 2002
- Monmouth
Hi there,
Wonder if anyone has any thoughts, tonight I've started having poor lentancy to the degree that a simple ping scan shows that I am dropping 1 in 4 pings The pings that do return are normally fine like so :-
Pinging www.adsl24.co.uk [84.234.27.45] with 32 bytes of data:
Reply from 84.234.27.45: bytes=32 time=16ms TTL=54
Request timed out.
My Traceroute is like so :-
Tracing route to www.adsl24.co.uk [84.234.27.45]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 16 ms 16 ms 19 ms lns4.uan.the.uk.murphx.net [94.30.127.75]
3 * 16 ms 16 ms er1.uan.the.uk.murphx.net [94.30.127.65]
4 15 ms 16 ms 16 ms ge2-6-1.crs2.core.the.uk.murphx.net [94.30.127.2
33]
5 16 ms 15 ms 16 ms ge1-2-1.crs1.core.the.uk.murphx.net [109.170.249
.29]
6 16 ms 21 ms 16 ms te1-4.cr05.te1.bb.gxn.net [62.72.139.29]
7 24 ms 224 ms 78 ms linx-extreme1.netrino.co.uk [195.66.237.18]
8 17 ms 16 ms 16 ms thn-edge.netrino.co.uk [84.234.19.142]
9 * 16 ms 16 ms hex-edge.netrino.co.uk [84.234.19.146]
10 18 ms * 18 ms bs1-core.netrino.co.uk [84.234.19.5]
11 18 ms * 17 ms bs3-core.netrino.co.uk [84.234.19.194]
12 18 ms 16 ms * adsl24.co.uk [84.234.27.45]
13 17 ms 17 ms 16 ms adsl24.co.uk [84.234.27.45]
Trace complete.
Normally all would be within the 15 - 16ms range. My ISP is ADSL 24 and they have performed a line test and all according to them is fine. I've replaced the filter just in case my line connection stats are like so:-
ADSL Link Downstream Upstream
Connection Speed 8128 kbps 448 kbps
Line Attenuation 15 db 3.5 db
Noise Margin 17 db 23 db
I can only get the "normal" ADSL connection so 8mb is my limit but I've never had this sort of problem with my current ISP, could it be a fauly router? I do have a old Netgear DG834 (Old Faithfull I call him)
My ISP asked me to leave it till the morning and if it's still a problem then report back and they will report it to the network guys
Any help
Request timed out.
33]
.29]
Trace complete.
Any help
