- 3 Dec 2011
Hello! I've had a BSOD twice today, with the message "page fault in nonpaged area". I did what most people in this situation would probably do - freaked out, and typed the message into google. This page seemed like a good troubleshooting guide, so I followed its steps: http://ohonei.hubpages.com/hub/What-Is-Page-Fault-in-Nonpaged-Area
I ran checkdisk on both my C and D drives while booted in safe mode (C being a SSD, D a HDD) and both returned no errors. I tried booting my computer with one stick of RAM instead of all four, one at a time. Each one in a different RAM slot in case one of the slots was the problem (if that's even possible), and the computer booted fine every time. I then ran memtest on every stick of RAM, allowing it to run all the tests on every stick in different slots, and again - no errors. They all passed.
The BSODs happened both times while playing Mass Effect 1, a pretty old game. I never get BSODs when playing Skyrim heavily modded, or Battlefield 3 maxed out. I have set a large address aware flag for Mass Effect to enable the use of more than 2GB of RAM, and I use texmod to play the game with some higher resolution textures. My GPUs and my CPU are barely stressed at all while playing Mass Effect, hence why I assumed the RAM would be the problem - and I believe that error message with the BSOD also suggests faulty RAM? I should also note that the first thing I did was run the blend test in prime95 - stress testing both the CPU and RAM for around half an hour before trying the other tests I mentioned above.
Any idea what could be causing these BSODs? I'm really worried that it could be something more sinister like a motherboard fault... but then why would the PC crash when running an old game like Mass Effect, and not a stressful modern game like Skyrim or Battlefield? So confused!
Thanks for reading, and any help or advice would be really appreciated
Oh, dxdiag in case it's needed:
System Information
Time of this report: 6/24/2012, 19:06:49
Machine name: -STEVE-PC
Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120503-2030)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: BIOS Date: 02/05/10 19:13:52 Ver: 08.00.10
Processor: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz (4 CPUs), ~3.4GHz
Memory: 16384MB RAM
Available OS Memory: 16360MB RAM
Page File: 2181MB used, 30538MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce GTX 560 Ti
Manufacturer: NVIDIA
Chip type: GeForce GTX 560 Ti
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_1200&SUBSYS_00000000&REV_A1
Display Memory: 4062 MB
Dedicated Memory: 2014 MB
Shared Memory: 2047 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: ASUS PA238
Monitor Id: ACI23B1
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HD15
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 8.17.0012.9573 (English)
Driver Version: 8.17.12.9573
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 2/10/2012 05:13:00, 17642816 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-5140-11CF-D546-0C201FC2C535}
Vendor ID: 0x10DE
Device ID: 0x1200
SubSys ID: 0x00000000
Revision ID: 0x00A1
Driver Strong Name: oem59.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section015:8.17.12.9573
ci\ven_10de&dev_1200
Rank Of Driver: 00E60003
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (Creative SB X-Fi)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1102&DEV_000B&SUBSYS_00421102&REV_04
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ctaud2k.sys
Driver Version: 6.00.0001.1348 (English)
WHQL Logo'd: Yes
Date and Size: 7/7/2010 14:16:24, 697816 bytes
Other Files:
Driver Provider: Creative
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: SPDIF Out (Creative SB X-Fi)
Default Sound Playback: No
Default Voice Playback: No
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Digital-In (Creative SB X-Fi)
Default Sound Capture: Yes
Default Voice Capture: No
Cap Flags: 0x1
Format Flags: 0xFFFFF
Description: "What U Hear" (Creative SB X-Fi)
Default Sound Capture: No
Default Voice Capture: Yes
Cap Flags: 0x1
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: HID-compliant consumer control device
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0xFEEB, 0xDEEF
FF Driver: n/a
Device Name: PTZ-630
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x056A, 0x00B1
FF Driver: n/a
Device Name: Mass Storage Device
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x058F, 0x6364
FF Driver: n/a
Device Name: Dell USB Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x413C, 0x2010
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Wacom Virtual Hid Driver
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x056A, 0x1001
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x1C2D
| Matching Device ID: usb\root_hub20
| Service: usbhub
+-+ Generic USB Hub
| | Vendor/Product ID: 0x8087, 0x0024
| | Matching Device ID: usb\class_09
| | Service: usbhub
Gameport Devices
PS/2 Devices
+ Razer Naga
| Vendor/Product ID: 0x1532, 0x0015
| Matching Device ID: hid\vid_1532&pid_0015&mi_01
| Upper Filters: RzSynapse
| Service: kbdhid
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ Wacom Mouse Monitor
| Matching Device ID: hid\vid_056a&pid_00b1&col01
| Upper Filters: wacmoumonitor
| Service: mouhid
+ Razer Naga
| Matching Device ID: hid\vid_1532&pid_0015&mi_00
| Service: mouhid
+ Wacom Mouse
| Matching Device ID: hid\wacomvirtualhid&col03
| Upper Filters: wacommousefilter
| Service: mouhid
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 111.5 GB
Total Space: 228.8 GB
File System: NTFS
Model: OCZ-VERTEX3 ATA Device
Drive: D:
Free Space: 1327.8 GB
Total Space: 1907.7 GB
File System: NTFS
Model: WDC WD2002FAEX-007BA0 ATA Device
Drive: E:
Model: ATAPI iHAS224 B ATA Device
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), , 0 bytes
System Devices
Name: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C26
Device ID: PCI\VEN_8086&DEV_1C26&SUBSYS_844D1043&REV_05\3&11583659&0&E8
Driver: n/a
Name: Standard AHCI 1.0 Serial ATA Controller
Device ID: PCI\VEN_8086&DEV_1C02&SUBSYS_844D1043&REV_05\3&11583659&0&FA
Driver: n/a
Name: VIA 1394 OHCI Compliant Host Controller
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_81FE1043&REV_C0\5&D93DF5B&0&1800E6
Driver: n/a
Name: Intel(R) 6 Series/C200 Series Chipset Family SMBus Controller - 1C22
Device ID: PCI\VEN_8086&DEV_1C22&SUBSYS_844D1043&REV_05\3&11583659&0&FB
Driver: n/a
Name: Intel(R) 82579V Gigabit Network Connection
Device ID: PCI\VEN_8086&DEV_1503&SUBSYS_849C1043&REV_05\3&11583659&0&C8
Driver: n/a
Name: Creative SB X-Fi
Device ID: PCI\VEN_1102&DEV_000B&SUBSYS_00421102&REV_04\4&1D7623A1&0&00E2
Driver: n/a
Name: 2nd generation Intel® Core™ processor family PCI Express Controller - 0105
Device ID: PCI\VEN_8086&DEV_0105&SUBSYS_844D1043&REV_09\3&11583659&0&09
Driver: n/a
Name: NVIDIA GeForce GTX 560 Ti
Device ID: PCI\VEN_10DE&DEV_1200&SUBSYS_00000000&REV_A1\4&80E7924&0&0008
Driver: n/a
Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 5 - 1C18
Device ID: PCI\VEN_8086&DEV_1C18&SUBSYS_844D1043&REV_B5\3&11583659&0&E4
Driver: n/a
Name: 2nd generation Intel® Core™ processor family PCI Express Controller - 0101
Device ID: PCI\VEN_8086&DEV_0101&SUBSYS_844D1043&REV_09\3&11583659&0&08
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_1200&SUBSYS_00000000&REV_A1\4&38AC18AC&0&0009
Driver: n/a
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_844D1043&REV_B5\3&11583659&0&E6
Driver: n/a
Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 4 - 1C16
Device ID: PCI\VEN_8086&DEV_1C16&SUBSYS_844D1043&REV_B5\3&11583659&0&E3
Driver: n/a
Name: 2nd generation Intel® Core™ processor family DRAM Controller - 0100
Device ID: PCI\VEN_8086&DEV_0100&SUBSYS_844D1043&REV_09\3&11583659&0&00
Driver: n/a
Name: High Definition Audio Controller
Device ID: PCI\VEN_10DE&DEV_0E0C&SUBSYS_00000000&REV_A1\4&80E7924&0&0108
Driver: n/a
Name: Intel(R) P67 Express Chipset Family LPC Interface Controller - 1C46
Device ID: PCI\VEN_8086&DEV_1C46&SUBSYS_844D1043&REV_05\3&11583659&0&F8
Driver: n/a
Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 3 - 1C14
Device ID: PCI\VEN_8086&DEV_1C14&SUBSYS_844D1043&REV_B5\3&11583659&0&E2
Driver: n/a
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_1B21&DEV_1080&SUBSYS_10801B21&REV_01\4&2B6CC657&0&00E6
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0E0C&SUBSYS_00000000&REV_A1\4&38AC18AC&0&0109
Driver: n/a
Name: Intel(R) Management Engine Interface
Device ID: PCI\VEN_8086&DEV_1C3A&SUBSYS_844D1043&REV_04\3&11583659&0&B0
Driver: n/a
Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 2 - 1C12
Device ID: PCI\VEN_8086&DEV_1C12&SUBSYS_844D1043&REV_B5\3&11583659&0&E1
Driver: n/a
Name: JMicron JMB36X Controller
Device ID: PCI\VEN_197B&DEV_2362&SUBSYS_84601043&REV_10\4&20221DEA&0&00E3
Driver: n/a
Name: Renesas Electronics USB 3.0 Host Controller
Device ID: PCI\VEN_1033&DEV_0194&SUBSYS_84131043&REV_04\4&DDEC341&0&00E1
Driver: n/a
Name: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C2D
Device ID: PCI\VEN_8086&DEV_1C2D&SUBSYS_844D1043&REV_05\3&11583659&0&D0
Driver: n/a
Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 1 - 1C10
Device ID: PCI\VEN_8086&DEV_1C10&SUBSYS_844D1043&REV_B5\3&11583659&0&E0
Driver: n/a
Name: 802.11n Wireless LAN Card
Device ID: PCI\VEN_1814&DEV_3062&SUBSYS_77221432&REV_00\5&D93DF5B&0&0000E6
Driver: n/a
Device ID: PCI\VEN_1033&DEV_0194&SUBSYS_84131043&REV_04\4&108ABD8A&0&00E4
Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,15.04.3555.0308
Record Queue,0x00200000,1,1,WLXVAFilt.dll,15.04.3555.0308
WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3555.0308
WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,15.04.3555.0308
WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,15.04.3555.0308
WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,15.04.3555.0308
WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3555.0308
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17713
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17713
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17713
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
Creative Recording Wav_Asio Filter,0x00400000,0,1,AudioRec.ax,1.00.0002.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17713
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17713
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17713
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17713
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.17713
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17713
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17713
File Writer,0x00200000,1,0,WLXVAFilt.dll,15.04.3555.0308
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17713
Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.17713
AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.17713
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.17713
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17713
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17713
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17713
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17713
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17713
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17713
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17713
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514
Fraps Video Decompressor,0x00200000,1,1,qcap.dll,6.06.7601.17514
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17713
Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17713
Audio Capture Sources:
Digital-In (Creative SB X-Fi),0x00200000,0,0,qcap.dll,6.06.7601.17514
"What U Hear" (Creative SB X-Fi,0x00200000,0,0,qcap.dll,6.06.7601.17514
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17713
SB X-Fi Synth A [0001],0x00200000,1,0,quartz.dll,6.06.7601.17713
SB X-Fi Synth B [0001],0x00200000,1,0,quartz.dll,6.06.7601.17713
WDM Streaming Capture Devices:
Digital-In,0x00000000,0,0,,
Microphone FP,0x00000000,0,0,,
Line-In,0x00000000,0,0,,
,0x00000000,0,0,,
SB X-Fi Audio [0001],0x00200000,1,1,ksproxy.ax,6.01.7601.17514
SB Live!2K Audio [0001],0x00000000,0,0,,
WDM Streaming Rendering Devices:
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
SB X-Fi SpdifOut [0001],0x00000000,0,0,,
SB X-Fi Synth A [0001],0x00200000,1,1,ksproxy.ax,6.01.7601.17514
SB X-Fi Synth B [0001],0x00200000,1,1,ksproxy.ax,6.01.7601.17514
,0x00000000,0,0,,
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Creative SB X-Fi),0x00200000,1,0,quartz.dll,6.06.7601.17713
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: SPDIF Out (Creative SB X-Fi),0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Speakers (Creative SB X-Fi),0x00200000,1,0,quartz.dll,6.06.7601.17713
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
System Information
Memory: 16384MB RAM
DxDiag Notes
Display Devices
Monitor Id: ACI23B1
Output Type: HD15
DDI Version: 11
WHQL Logo'd: Yes
WHQL Date Stamp:
Vendor ID: 0x10DE
Device ID: 0x1200
Revision ID: 0x00A1
DXVA-HD: Supported
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Cap Flags: 0x1
Cap Flags: 0x1
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
USB Devices
+ USB Root Hub
| Service: usbhub
+-+ Generic USB Hub
| | Service: usbhub
Gameport Devices
PS/2 Devices
+ Razer Naga
| Service: kbdhid
| Service: kbdhid
| Service: TermDD
| Service: mouhid
+ Razer Naga
| Service: mouhid
+ Wacom Mouse
| Service: mouhid
| Service: TermDD
Drive: C:
File System: NTFS
Drive: D:
File System: NTFS
Drive: E:
System Devices
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
DirectShow Filters
DirectShow Filters:
Video Compressors:
Audio Compressors:
PBDA CP Filters:
Midi Renderers:
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
BDA CP/CA Filters:
Audio Renderers:
Quality Flags: 2576
Enabled:
Force throttling
Allow scaling
Enabled:
Force throttling
Allow batching
Force scaling
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
