I wasn't sure wether to post it at monitors or graphic cards, so did it here.
I'm having some really annoying tearing issues (page tearing, screen tearing) , I can fix it at games by putting vsync on or forcing it with D3DOverrider but there are two things really annoying me.
Vsync doesn't work in windowed mode (@ WoW, TF2), I do get capped at 60 fps but there is tearing, having vsync ON in windowed mode sometimes even makes the tearing worse... This is really annoying, since I need windowed mode to watch movies while playing (always on top stuff).
I can't get vsync to work in CCC, so I get tearing when watching movies, D3Doverrider also doesn't fix that... I do notice that the tearing is worse on my 32 inch tv with a hdmi cable then on my 20 inch with a dvi cable...
Anyone knows how to fix this? I've been googling for months know and it's really annoying the hell out of me D: Speccs:
Hd4870 512 mb OC
E8400 @ 3.4 ghz
Msi P35 Neo-f
4 gb ram
620 volt electricity supply (so that isn't the problem).
My temperatures are fine, Hd4870 gpu is ~35 degrees on idle and my processor 31 degrees idle... And that are the temps when watching movies to.
Thanks.
Edit: Also got the newest drivers with a CLEAN install and also tryed 8.11 a while ago but I vaguely remember that also doesn't work.
Hd4870 512 mb OC
E8400 @ 3.4 ghz
Msi P35 Neo-f
4 gb ram
Thanks.
Already was able to fix the tearing when watching movies, had to delete something that I used to be able to play HD on some program, and reinstall all mediaplayers.
