PAGE_FAULT_IN_NONPAGED_AREA
Hard drive or ram issues then. Run a few passes of memtest86 on your memory and perform an error scan of the hdd using something like hdtune.
Spyware does not normally do that, it's purpose is to spy not destroy. No point in formatting without running the scans as you'll just get the same problem again if it is a hardware problem.
Yeah do the memtest and Seatools is good for testing hard drives (works for most makes in my experience, even though designed for Seagate drives).
EDIT: you just posted above me, Crucial RAM does seem to fail a lot can be that.
Yeah CD or I think it works on a floppy too. If you want to test the RAM properly it's recommended to leave it on for a few hours (memtest is just a continious test).
ok cheers i will do that if its dead will overclockers send me some new sticks? 3 months old
It says on the page you just linked to.
"- For warranty support and RMA replacement call Crucial Direct on 0800 013 0330 or 01355 586 100 who will replace your faulty memory within 48 hours."
